Hi all,
I had dropped my 2000 SV650 one day, and had to replace the gear shift lever. After that, while I was starting my bike, it turned over a couple of times, and then just died. By died, I mean that the lights and instrument panel are all fine, but the starter relay doesn't click.
I'm sure it is some tiny electrical problem, but I'm not too familiar with electrical or mechanical things, so could use some advice/help.
I have checked all the fuses (including the 30A ones), and they all seem fine.
The bike is in neutral, clutch pulled in, kill switch on, and sidestand up.
I got a multi-meter and the battery puts out 12+V. Not sure what else to check, or rather how to check other things.
Thanks in advance for your help.
