1 - 4 of 4 Posts
this bike has been so good to meand I have kept it up and maintained it well. but here lately its bein goin down hill and I dont know whats causing it.. we're talkin rugged weak sounding idle, it cutts out every once in a while, that bike has never not once fail to crank on the first push until the other day. and the biggest issue is it lost so much power especially on the mid top range and tbe teach bounces up in the high rpm. does anyone have any insight on this? someone said it could be fuel pump relsted. it has 36000 on it thanks
too vague... could be anything. but lost power makes me think either sv325 (clean drain hole) or valves being too tight
let's try the other way... what have you tried/tested so far?
bike needs suck/squeeze/bang/blow to run. (air/fuel,compression,spark/time,exhaust)
have you looked at spark plugs?
put fresh gas in?
measured voltage on battery?
Discussion Starter #4
no if checked all the plugs they look good. air filter and oil is good. I took the fuel pump out and looked at the filter and got all that gunk out and put it back now it want crank at all any ideas what could have happened?
1 - 4 of 4 Posts
