1 - 9 of 9 Posts
First track day coming up and i was wondering if theres a fuse on my 02 svs to shut all the lights off,? instead of pulling all the harnesses out.
There are only 4 fuses low beam, high beam, ignition, and signal lights. If you pull out the one marked signal lights it will kill everything but the headlight and ignition. The only thing is you will have no tach either.
mario60185 said:
cause the tape will probably melt. id rather just pull a fuse.
I was at the track this weekend in 95+ degree weather and had no issue with the tape melting.
1 - 9 of 9 Posts
