used gsxr rear shock(new as possible) 100usd(or less)
new hh brake pads and stainless lines 150usd
yamaha r6 throttle tube 15usd
new fork springs and fork oil 110usd
factory pro ignition advance kit 55usd
factory pro carb kit 250usd
used slip-on 150usd
approximately 830usd
less than a grand and you'd have a nicely refreshed bike.
cosmetic stuff?
if you have an svs maybe go naked. or put plastics on your naked!
ebay has a lot of international shippers, so i would start there for sure.
good luck!
ps
with that many miles i can only assume you've been doing regular maintenance stuff.
if not, i could make the list a little longer
clutch cable, rear brake line and fluid, throttle cables, carb service(clean and rebuild), chain and sprockets, tires, spark plugs, valve inspection/adjustment, carb sync, etc.
used slip-on 150usd
cosmetic stuff?
good luck!
ps
