Bump 🪩
sounds like the kickstand switch if thats the case...Is the condition that the bike will start and run in neutral, but not when it is in any other gear?
Interesting suggestions, thanks. I’ll answer in order.A few questions that might help...
If you try to bump start it in first, does the engine turn over?
Does the clutch release, can you push the bike easily in first gear with the clutch lever pulled in?
