...against the chain buffer. I tightened the chain trying to stop this thinking it was just too loose, but now the chain has about 1/4" of play and that's too tight, right? Does anyone know if there is an acceptable amount of rubbing that should be going on w/the buffer? I can feel it resonate when I hug the tank w/my legs. When I look at the buffer it appears that the chain is making new grooves from rubbing. Can you help a brotha out? ???
Cliffs:
-chain rubs against buffer enough that I'm worried
-stock height, links
-no swingarm or suspension adjustments that I'm aware of
Just in case you're wondering WTH I'm talking about it's part #9 pictured below:
Cliffs:
