1 - 20 of 135 Posts
My other bike, 45mph+ on a electric bicycle during the busiest street. Technically a motorcycle disguised as a bicycle.
Charging my 20v batteries in parallel, 83volts of pure DC power.
Weighs about 55 lbs without batteries so I can carry it on my car.
Motor requires virtually no maintenance, only have to replace the bearing on the axle every 50,000 miles or so. Its a $2 part.
Build details? That thing is pretty slick. With the video sped up I can't tell how fast you're going but I noticed you pedaling from time to time. Going up hills or just feel like moving your legs?
Discussion Starter #3
Video is normal speed, I pedal to put less load on the motor, conserve battery power.
Details:
Giant Trance Full Suspension Mountain Bike
Shimano 4-Piston Hydraulic Disk Brakes with 203mm disc rotors front and rear
Motor is Crystalyte HS3540, direct drive rear hub motor.
Batteries are RC Lithium polymer 84volts, controller is set at 50Amp discharge, giving about 3800watts of power under full throttle.
What is the range on that battery? At 50 (49.5) mph isn't it legally a moped and need lights, and approval, and stuff? Is it as much stupid fun as it looks? When do you do the dirt(trail) bike version?
And where's the engine noise? (None on the videos. ;D)
Discussion Starter #6 (Edited)
And where's the engine noise? (Non on the videos. ;D)
Range depends on speed, under hard riding about 10-20 mile range. Taking it easy 30-35mph with cruise control brings it up to 30 miles. Wind resistance kills battery power, and over 20mph wind drag is substantial. On the bike trails with my financee we go 20mph with pedalling easily close to 75 mile range.
Well technically it is a moped but I can pedal with the motor off, it rides and looks like a bicycle.
Yes, its stupid fun as it looks, my SV650s just sits in the garage all week. My electric bike is my daily commuter, its fun to pass cars and motorcycles on a electric bicycle.
The slick tires I have on are ok for light trails. I'm going to build a dedicated off-roader in the future.
Heres my fiancee's 38mph geared electric bike, sounds nice.
Out accelerating cars gives me a grin everytime.
what was the cost of the equipment to set this up (not the bike itself, just the equipement)
i am seriously considering doing this....
Discussion Starter #9
Heres the motor I used:
http://www.ebikedeal.com/crystalyte.htm $350 and It already comes laced into a standard 26" wheel for mountain bikes.
http://www.lyen.com/ Get the 18fet controller about $200
http://www.ebikes.ca/product-info/grin-products/cycle-analyst.html
You'll need a display that will tell you battery capacity, voltage, speedo, cruise, throttle tuning, etc. About $150
I chose RC batteries because they are lightweight and powerful. You will need about 6 of these for 70volts, and 8 for 100v, easily over 50mph top speed.
http://www.hobbyking.com/hobbyking/store/__9176__turnigy_5000mah_6s_20c_lipo_pack.html
About $400 for batteries.
Heres the best lithium battery charger.
http://lipoconnectionsolutions.com/iCharger-308DUO-1300W-Dual-Channel-8s-Balance-Charger-308Duo.htm
About $269
http://lipoconnectionsolutions.com/24v-62A-1500w-Power-Supply-for-RC-Chargers-2462.htm
I use these Dell server power supplies for my charger, takes 30 minutes to fully charge my batteries at 40amps.
Now there are cheaper parts out there but the ones I've listed are the highest quality.
Discussion Starter #15
4 piston hydraulic brakes in the front and twin piston in the rear.
Also 8 inch rotors.
More than enough stopping power, the rear comes up if you jam hard on the front brakes.
Front:
Rear:
The bike also has regenerative braking, its like engine braking but also puts a bit of electricity back into the battery.
how does gearing work exactly? are you changing gears? only 1 gear? i dont really see you changing gears....
Discussion Starter #17 (Edited)
On my bike, I'm always in the highest gear. The bike accelerates so quick, shifting is just a waste of time.
Now, the motor itself is direct drive so its only "single speed". Electric motors have a wide torque band, and power increases as rpm goes up so there really is no need for gears.
Even the fastest electric vehicles like the Lightning motorcycle, Tesla are all single speed. Now there are some electric bikes with gears, those are called mid drive. But since my commute is mainly flat, I don't need gears. Plus, I can focus on riding instead of fumbling around with the gear shifter. Unless a gas motor, theres no clutch either. Dead simple.
I just twist the throttle and it goes.
Any point in keeping derailer there then? Awesome build by the way!
Discussion Starter #20
Thanks, no point at all I'm removing it in next build and just changing the drive train to single speed.
My new motor just came in today, its called the Cro-motor its the most powerful hub motor that will even fit in a standard bicycle.
With moped tire.
Not my wheel but I will running on a standard 26" downhill rim.
More details about the motor.
http://www.zelenavozila.com/#!cromotor/c1ger
1 - 20 of 135 Posts
