1 - 2 of 2 Posts
So I've decided I want to chop my muffler. Is the process really just cutting the pipe off at your decided length, removing the end cap then reattaching the end cap to the newly chopped section??
I think it can be done more neatly by grinding off the rollover at the tip, pop the spot welds and slide the whole inside of the muffler out (with the tip still attached) Then you can cut the innards, cut the can, slide the guts back in and one tiny pin or rivet will hold the tip on. (rather than 3 or 4 that look like :puke:)
1 - 2 of 2 Posts
