1 - 4 of 4 Posts
So I got my hands on a OEM belly. I always thought I just needed front bracket as the rears bolt on to the engine. It seems that I am wrong.
I know the front two bolts need a bracket off the engine normally. But the rear one I don't know if a bracket would work. Like the brake side how does it mount?
I'll snap some pictures
Sent from my Galaxy Nexus using Motorcycle.com Free App
You can make the brackets to attach to nearly any case-cover bolt on either side. Below are pics of my bike. Not the best pics to illustrate my point but you can see the little black brackets on each side. On the right side, the rear attaches to a case cover bolt (the same one pictured in your first pic - it also holds the wire guide that directs your overflow hoses). On the left side, the bracket attaches to the front sprocket cover bolt.
Case cover bolt
Hard to see, but a small black bracket runs up to the rear of the front sprocket cover (near the shifter)
1 - 4 of 4 Posts
