MotoSliders vs. R&G?
+1 on Nexus' post. So what you were saying is that the R&G still only connects to the bike via ONE bolt? I mean, if that's the case, it would seem as if there's absolutely no benefit. I could see pressure being spread across two bolts being more suitable, but if that's not the case....
That is not what was said, The R&G are connected to two bolts, so in the new MotoSliders design,
However you have a naked version of the SV650, so your needs are not the same as those with full fairings,
In your case, the through bolt design of the Standard version of the MotoSliders is the one for you,
Much less expensive than R&G, for your application, and just as good protection,
I have many customers using the MotoSliders, and have yet to have one complain that they did not perform as advertised,
Enjoy the ride, and best regards,
Blair
