1 - 16 of 16 Posts
Does anyone have any experience with one of these? If so, how well did it work? I'm looking for something to carry my bike , but I don't want to get a trailer because I don't have anywhere to park it.
I use one on my blazer for smaller dirtbikes and my moped. I wouldn't put my SV on it though. Just too heavy. Unless you're driving a truck, but then you wouldn't need the carrier.
I have one that I haul my dirtbike on when I can't catch a ride with someone else. I barely trust it with a dirtbike (and have dropped the dirtbike 2x off of it so far, but those were both on rutted out dirt roads). There is no way in hell I would trust one with a full weight street bike, there is just way too much torque on the hitch receiver as well as the fact that your tiedown points are way too close to the center of the bike so you have very little stability.
very big dumb
if you have a class 3 hitch, the tongue weight is 500lbs. AT THE HITCH. Since that rail sticks out, it's a lever so you can't actually put 500lbs on it. Since it weighs a few lbs itself, you're REALLY pushing it putting a 400lb sv on it.
Yeah if I had a truck there wouldnt be an issue, but i drive a jeep wrangler. I figured the weight of the sv would create a significant moment about the axis of the hitch. OK, i guess i need to start looking at other options. Maybe I'll shell out a little extra and get a small trailer. Thanks for the input.
very big dumb
something like this may do well for you if you don't have a ton of space to store a trailer? http://www.northerntool.com/shop/tools/product_200466701_200466701?cm_mmc=Google-pla-_-Trailers%20%2B%20Trailer%20Parts-_-Trailers-_-14717&ci_sku=14717&ci_gpa=pla&ci_kw={keyword}
ditto on my dirtbike carrier-would not trust a full size street bike on one of these
It's not just the tongue weight that is the problem, but when you make turns or are anything less than perfectly level the carrier will lean a little side to side (the torque I mentioned before). Receivers aren't made to take stress like that, since hitch balls are spherical. eventually it could weaken or bend the mounting points between the receiver and the frame.
very big dumb
didn't think of it that way, was just thinking in terms of ratings. :eek:ccasion14:
We drove my SV home on a cheap Chinese version of one of those mounted to the back of a Ram 1500. Eh.. I wouldn't have wanted to be behind us. :)
But it made it home just fine. If you're going to do that try to get the beefiest one they have.
You learn how unsteady they really are when you get off the pavement and start bouncing around. On mine with a 250lb dirtbike it will tilt/twist/bend 3" or so at each end, it has that much play in it. It's rated for 400lbs and I have a reciever rated for 500lbs.
Trailer-in-a-bag is great if you're short on space but long on cash. It's expensive. (IIRC, around $1,200).
If you are short on space and cash, Harbor Freight and Tractor Supply Company sell folding trailers (the base is hinged in the middle) that sell for around $500.
That is too much weight on the back of a car or even a half ton truck. Your front end will float and make steering dangerous.
Too bad though, I've tried the same thing and like everyone says, even a dirtbike is too heavy.
I don't think a Wrangler has a hitch that is capable of supporting this. And either way, imagine if you hit a dip in a highway. That 500lb in bike and carrier you have all of a sudden became 800lb, if not more, due to gravity.
If you have space that's 5 feet wide, 2 feet deep, and 5 feet tall (it would easily fit in my garage spot, and my Lancer Evolution is probably longer than the Wrangler), get a folding Harbor Freight trailer, replace the wheel bearings, add some plywood for the floor and you're done. They routinely send out 25% coupons, so you can get this all fitted out for under $300. If you're really strapped for space, then you can spend $650 for a used Trailer In A Bag.
1 - 16 of 16 Posts
