1 - 16 of 16 Posts
· Registered
I tried to buy new ones but the company is DOA. So the best way to fix anodized aluminum is?
I am thinking heat it with a Oxy/Acy torch and pound it flat on a surface plate better ideas to prevent cracking and ruining the plate.
· Registered
heat, hammer, something as an anvil. I wouldn't use acetylene, as it may get to hot and aluminum doesn't like it (It'll spray if you hit the oxy). I would think something like MAPP gas would serve to heat it up enough to make it flexible.
· Registered
I have a heating tip, I have propane no Mapp here, I have used the OXy/Acy a lot and I know what to much is.
It looks like it was billet 7074 Aluminum of 7071 I can't remember now. I'll do the heating and hammering. I don't have a smooth jaw vice so I don't want to chew on it. I did think of it though.
· Registered
The other reason I don't want to use a vise is that clamping to straighten creates new bend points on it. Further weakening it.
Heat on the areas that are damaged will soften it to allow for re-bending.
Also if I clamp it straight it creates a grip and as you straighten it, it needs to slide because it will lengthen.
I have taken some tool and die, just not a lot and I didn't know if the metal heads here would have a better opinion of it.
· Registered
Discussion Starter · #10 ·
spacing is different they are One Second Faster one off rearsets. ZThey claim th eparts were in stock. After 6 weeks on order and no response from numerous calls and emails I had to file a claim with my Credit Card to get my money back.
· Registered
I'd use a press if you can access one. Much more controlled than smacking it with a hammer, and usually works better, too. That's what I used to straighten my woodcraft rearsets that had a similar tweak after my highside.
My $0.02.
· Lifer
Have you tried a vice to straighten it out?
If it's made from "aircraft aluminum", it's meant to bend and not break.
When I spoke to Blair from SVRacing Parts on the phone, that's what he told me. Granted I have the SVRP rear sets but I'd assume the same thing for all of the motorcycle rearsets out there (they cost a ton for a reason).
· Registered
Discussion Starter · #16 ·
I forgot I have a press sitting in the corner, pressing it it is. I will post pics.
1 - 16 of 16 Posts
