While I was adjusting my valves this weekend I’m pretty sure I messed up the timing by moving the crankshaft while the chain tensioner was out of the rear cylinder :nono:.
I had just replaced the shims on the rear cylinder, returned the cams to their position at ATDC and bolted down the journal holders. While I was waiting for the gasket remover to do its job on the rear tensioner I wanted to check the clearances on the rear at TDC so I started to move the crank like an inch or two and realized the freakin’ chain and cams were not moving. I realized what I had done and was going to just go back (clockwise) that inch but I didn’t want to start compounding the problem. So, what would you guys recommend I do?
The only thing I can think of is:
Take the cams off the rear cylinder again.
Bring the front cylinder to TDC while allowing the rear cam chain to freely loop around and then another 360 degrees turn to bring the timing back to ATDC on the rear cylinder.
This method should work right?
