So I have a new chain and I want to make sure I cut the right number of links off. Where should the rear axle be when you measure the slack in the chain. I know the chain will get strech so should it be forward of half way??? The chain I am putting on has a masterlink with a clip so I don't need to be able to push the wheel forward to get the chain off. So I guess that means you could have it all the way forward>>that doesnot seem right though. Please help.
How many links does your old chain have? I'd go with the same unless you're changing gearing a lot. If it's only one or two teeth, then you can probably get away with the same number as the old one.
Well I am going from a stock chain and gearing to a 520 chain with one down and two up gearing so it is pretty different.
One down in front, and two up in the rear? You could probably get away with stock #, or maybe 2 additional links. Heck, do it stock+2, and if it's too long, take the two off. It's easy to take the links out, not as easy to add them back in.
I have the sprokets on and the chain is on just not with the clip snapped ont he masterlink. My question is where should I have the rear axle. Will haveing it in the middle of the tension adjustment (forward/backward) give me enough room to take up the slack as the chain streches??? Sorry if this is a dumb question.
