I tried to search for this a number of ways but cannot find what I wanted.
Is there a difference, either in piston size or other internal components, between the 2nd gen's ABS models Vs. the non-ABS models?
Comparing the two at BikeBandit shows a different part number for the KA assembly.
Text Line Font Screenshot Parallel
Since all the other part numbers are identical, the piston/cup/cylinder arrangement is different for ABS models.
How? shape, Diameter, length, material? Why? Dunno. Anybody?
Is there a difference in piston size between the 2nd gen's ABS models Vs. the non-ABS models?
I don't know. Do you have ABS? If you do, it wouldn't be hard to figure out the answer.
The piston size is usually marked on the side of the master. It will either be a painted number that corresponds to millimeters, or an inch fraction cast into the body.
If I remember right, non ABS is 5/8 inch. (16 millimeters)
The piston size is usually marked on the side of the master. It will either be a painted number that corresponds to millimeters, or an inch fraction cast into the body.If I remember right, non ABS is 5/8 inch. (16 millimeters)
Numbers below the sight glass on my ABS front MC--
Code:
14 8 C 4
If you replace a 14 with a 16, you'll get 24% less force for each millimeter of lever movement.
Unless you change the wheel cylinder size as well, like they did!
Text Font Line Number Document
And why are ABS parts always twice as expensive? We paid $500 extra up-front already, guys!
