1 - 8 of 8 Posts
We are planning on taking my wife's 2003 SV650 in for the valve adjustment and a tire change to a recommended local shop this weekend. BTW, she just put 5350 miles on it in a 18 day trip we took from GA to Boise and back. Pretty cool stuff. The mechanic recommended that we also swap out the automatic cam chain tensioner for a manual one for a smoother operation with less chance of chain slippage. The cost would be $55 for parts and 1/2 labor @$65/hr.
I haven't heard nor could find much info on this on the board. Is this job worth it and have there been instances of what he describes?
Thanks, Trent
We use them on our race engines. APE billet tensioners. They work and are strong.
I have "heard" of a lot of people "hearing" about these issues...but this is a forum. 99.8% (yes, that is accurate :) ) of the people on this board use stock tensioners. What I am saying is this...someone comes up with a new shock substiution and suddenly everyone has it. Someone claims the cam chain tensioners are bad, and noone does anything, risking possible engine damage. I dont think there is too much merit in needing manual tensioners. I know the design is different from the 99-02 to the 03+ models. The newer ones are a little more manual then the old. They both seem okay to me.
ac
Thanks guys...so it seems as if for normal riding use they are probably not needed? Has anyone had to replace the stock before let's say 50k miles?
I haven't had any problem with my cam chains in 115k, sure they make noise, no big deal, a manual tensioner is just one more regular maintenance task, IMHO tight chains are bigger danger to engine than a loose one, and a manual tensioner has more potential to be improperly tensioned
Stock tensioner: set it and forget it.
Manual tensioner: needs regular adjustments.
Also, you'll need two of them. One for each jug.
Thanks everyone for the quick and informative replies. Looks like I will save around $180 by asking here first.
1 - 8 of 8 Posts
