Before i get started on checking the TPS (which can be adjusted with an Ohm reader?) I want to make sure that its the problem.
When i hold the throttle at a low position, about 1/4 turned, the bike holds its rpms, hesitates and then pulls harder. When i hold the throttle in a steady position, when riding, it jerks back and forth, like its accelerating, decelerating, accelerating, etc.
What i've noticed today when i warmed it up, was when i pull on the throttle, and let go, and pull on it again (repeat a few times) the bike turns off.
I am going to be doing a carb sync and re-jet, however if i should do the TPS thing, i might as well.
let me know what you think.
-Zabi
-Zabi
