1 - 3 of 3 Posts
my 03 sv650s completely wigged out. the engine starts fine, but whenever you put on a turn signal, the engine cuts off! then the hazards start to blink for some reason, and as they blink, u can hear the fuel pump (i think its the fuel) pump, the thing that makes a sound when u turn on the kill switch) turn on and off. anyone EVER experience this??? everything works fine until u basically put a turn signal on. all the fuses are fine, so i have NO clue what is wrong. any ideas??
check your battery conecctions for corosion & tightness, then check you charging system
Check wires for worn spots (shorts)?
Curse at it and tell it what you'll do if it dosen't start to behave.
1 - 3 of 3 Posts
