So I've had this 03 for about almost two years now. The only thing I miss about the 07 I had was the gas mileage, it got 50-55 consistently, no matter how hard I was on it.
My bike has at least 25K miles on it. Just going through and seeing what the culprit is for my poor (33-38 mpg) mileage. I get the same mileage when I ride hard as when I take it easy (at least it seems that way).
Maintenance Items - Date of last check:
Air Filter - Stock, changed in August, still clean
Oil - Amsoil Full Synthetic @ 19k miles, below F and L.
Coolant - Unknown, topped off last week.
Valve Clearance - Approx. @ 15k miles by PO
Chain and Sprockets - 2k miles, Last May, 15/44, Dupont lube weekly, EK Gold 420
Chain Slack - Checked weekly
Spark Plugs - New NGK plugs in Sep. 06
TPS - Set by PO, never messed with
Idle speed - 1.2k rpm
TRE - Done in September '06.
What else can I be missing here? I feel like it's running a bit rich.
Bout to drop the engine for a cam swap, busa pistons, new plugs, valve clearance check... might as well get some more maintenance items in while we're at it.
