Hi guys, first posting here.
Want to share my good results with the Coleman Maddog ATV seat cover with my 2002 SV650N. Widely available for $20.
55197
Was having a very big problem with the stock seat. Like to sit as far forward as possible, and let's just say things were getting crowded. Particularly on bumpy downhills. Ouch!
(Squeezing the tank with my knees helped, but I ride way too much for that; gel seat might be worth a try, but lower aftermarket seats not of interest.)
This cover has made a huge difference. Main benefit is the padding that rides up the tank, but overall comfort also dramatically improved.
These are not waterproof, and are said to soak up water, but somehow this hasn't been a problem on another bike I have.
The pad has 3 straps. Front strap easily goes under gas tank; middle strap under rear of seat, though better to cut off buckles and tie it on; rear strap will be removed with excess seat cover.
Rear of seat pad needs to be removed. Cuts really easily with scissors, and top of pad is bonded to the gel foam, so just cut it and forget it. (Pretty nice gel-type foam also.) DONT REMOVE TOO MUCH OF THE PAD--remove less than you think, then trim for a nice tidy fit. ALSO, RESIST TEMPTATION TO CUT AT SEAMS BETWEEN THE RAISED PADS; just cut through the pads.
55198
Second photo shows pretty well the crazy s*** going on at the back of my SV. very successful replacement of rear seat with cargo platform to accept saddlebags (for when bike may go down in the dirt) and custom panniers/topbox/whatever I want (for utility use).
Pad also makes the seat a bit taller, which is nice for leg room, but doesn't help getting the bars raised to where I want them. :-(
Nice little ad hoc $20 mod that addresses a major pair of problems. :)
That’s an awesome fix. I have a stock gen 1 N. With that horrible stock seat and a found a used Corbin same year from an S. Stock sucks after an hour. The Corbin is like a rock but the shape is awesome.. was there a specific pad or are they one size fits all? Can I ask if you have ridden more than a couple hours and what’s your thoughts now after a few more miles? Thanks for the post.
Nice find and work :)
You can give it some waterproofing using GT85 PTFE Chain lube. I use it on my Gloves,boots and jackets. Warning! GT85 smells nice but is pervasive so only use outside. The smell takes time to die.
GT85 is plentiful here in the UK but this should work just as well,
PTFE is inert and does not affect stitching and in fact prolongs it. My Bike Jacket is 15 years old and none of the stitching has rotted :)
Discussion Starter #4
Thanks for the replies, guys. I don't seem to be getting emails regarding this, best to check my settings I reckon.
There's only one size of this pad, usually called Maddog or sometimes Coleman. Haven't done a lot of time with it, but so far, it's day and night. (Though I am still looking for what makes this bike hard to control when walking it around while mounted. I think it might be the relatively low bars, or maybe the seat shape.)
For me, it's critical that first panel of the seat pad rides up the tank to provide the necessary cushioning. Pad kind of wants to slide back an inch or two.
Just threw one of these pads on my DR650, haven't even tried that yet. Couple hours ride to the dirt for me. :-(
