1 - 20 of 99 Posts
· Banned
Every 8K miles I'm puting a chain on my bike... :p the links stop bending as it comes around the sprocket and goes from loose to tight - makes a ton of noise. My buddy has a Buell XB-12R with a belt drive, I cussed at him this weekend b/c I was jealous he gets 25-30K on a belt!
So I always buy the X-ring chains, and lube them about every 3rd ride using the oil-type motorcycle chain lube (similar to WD40). I used to use the suzuki lube but it was so thick it caked everywhere and was messy. The roads are now covered in DOT POOP so that's probably why this chain only has 6K and its starting to suck but during the summer it's not much better.
Anyone got any ideas as to how to extend the life?
Any particular lubes you find to be the best?
A brand of chain that may last a little longer?
Is X-ring really any better than O-ring?
Should I be oiling every ride or is that overkill?
· SV Hadder
are you keeping the chain in proper tension?
if you actually keep it clean and lubed every third ride and in proper tension, you should get much more than 8k.
Out of curiosity, did you change your chain without changing sprockets? If so, you can wear out a chain faster.
· Registered
8k? You are either getting chinese chains made of lead or you are doing something wrong. Either way...FAIL. Get someone to go over the entire chain maintenance routine and watch them. Ask questions and repeat until you are sure you are doing it right.
· Registered
I was having similar issues,(bound links) even w/ meticulious cleaning,& 1-2" of slack adj.... soo i bought a 9,500lb. tensile strength $155.00 chain, i believe D I D makes it, it's a #525 ZVM2,
& it solved my problems.
· Registered
Ur post only mentions that u lube the chain, but not clean it. It needs to be cleaned as well as lubed if u don't. I like maxima chain wax. No fling and stands up to road gunk in the rain here in oregon. 13K on my chain so far, but might need to be replaced at 15k. Slack is coming faster and faster now with tiny kinks. We'll see. I clean and lube every 1k miles
· Banned
Thanks for the ideas - Lets see, to answer in order
Zach - I check the tension, and its starting to get loose but the links bind just before an adjustment is needed.
The first chain I put on @ 8K I did change the sprockets (stock #), but the 2nd chain (about 16k) the shop told me the sprocket looked brand new so I didn't. Funny thing about the shop is, I went to a better shop for my tires the next day and the guy commented on how tight the chain and axle bolts were. (should I call them out? - cycle shack in Roanoke, VA :spank:)
Fivetoez +1 - thanks
Trunkmonkey - I actually don't clean it with lamp oil, but the I use the lube in excess so that the spray velocity and composition blows off most of the dirt. I will definately try better cleaning.
I noticed at lunch that the chain has been excessively heated - I could see discoloration on the bare metal that touches the sprockets. I'm wondering if my wheelies are f'n it up???
· Registered
Consider a manual (Loobman) or automatic (Scottoiler) chain oiling system. Some of the testimonials/reviews of chain life are incredible...
These will help if the chain is adjusted correctly. I really don't think it is.
· Premium Member
with a scottoiler, my front sprocket wears out at about 35,000
chain & rear sprocket hardly show wear but I change as a set
· Registered
I got about 18K on my stocker. I ride the same roads as Jballa and usually carry a 120LBS passenger 70% of the time.
I keep mine adjusted, wash the chain twice between oil changes. Lube with Maxim Chain Wax bought at Lynchburg Suzuki FTW.
Probably adjustments are not correct causing binding or bending links. Wheelies shouldn't hurt a chain to much cause some excessive stretch, I wouldn't know the Reckless tickets and bike impoundings are getting pretty hefty in my area.
Jballa are you rotating the tire evenly whenever you tighten or lube your chain.
· Registered
i was sorta slack on my adjustments, and only oiled my chain every few hundred (never cleaned it) and it and the sprockets were fine at 13k when i sold my SV. guess i got lucky.
my drz is at 4k and is fine, same thing i only oil it and adjust it when it get way out of whack. but its a sumo so i dont expect the chain to last as long.
buell has a belt :p
1 - 20 of 99 Posts
