1 - 20 of 30 Posts
· Registered
Would it be a good idea to put a little bit of LocTite on the threads of the bolts that you use to install swingarm spools?
I would think so just because of the vibration that's gonna go thru the swingarm when you're riding. Don't want them to work their way out and come off.
· Super Moderator
If you don't use loctite, get used to the idea of bolts and parts falling off in the road.
· Super Moderator
The SV also ... my horn is along some road in NH ... so are the bolts that hold my gastank. Your kit is now put to good use! :thumbsup:
BTW, all those parts fell off after I brought my bike to the dealer ... I never returned as a result of that experience.
I now torque all my bolts and use loctite blue or green. On everything but axle bolts.
· Registered
I never loctite anything on the SV, other than what it calls for in the manual..rotors bolts, etc. Proper torque spec has always worked for me.
· Registered
would recommend not. its not an integral part of the bike in the first place and secondly I recently sheared a spool bolt off in my accident and had to use a bolt extractor for the first time. It really would have been a PITA if I had used any locktite at all on that bolt... I'm guessing.
· Registered
+1 Proper torque for the win. Bolts are designed to stay tight indefinitly if torqed properly. Since this is an M8 going into steel you'd want to do around 20N-m. If you don't have a torque wrench just do it til its snug and then a little bit more.
· Registered
It shouldn't hurt anything, it's probably a good thing.
Blue Loctite is extremely easy to remove, I sometimes think it doesn't do anything. But I do use it on certain bolts, of course only metal to metal contact.
1 - 20 of 30 Posts
