1 - 7 of 7 Posts
Would the blue locktite Suzuki sells make it too difficult to remove bolts/nuts from the bike? I don't want to experience the falling-off-shifter syndrome.
2005 Blue SV650s: 375#
+ Rider with gear, soaking wet: 135#
= Good times.
blue isn't too bad... red on the other hand... ;D
It also has the added benefit that it helps prevent the threads of the bolt/nut from getting fouled up with rust (which can actually make it easier to remove ;) ).
Don't use red loctite on something unless it's specifically called for. Red loctite high strenght and pretty tenacious. It's generally safe to use blue anywhere unless the bolt threads into plastic.
Ive heard of people doing this on dirtbikes and such. how do you go about it? How does the safety wire keep the bolt from turning?
You drill a hole in the bolt head or carefully through one of the "points" of a nut and then do like in the pics...
Safety wire has been around forever and is still used on critical fasteners on everything from printing press's, race cars and air/space craft.
1 - 7 of 7 Posts
