the fork tubes on the SRAD are 55mm. So, the LP headlight brackets are not going to work. I have an idea about using 3/16" steel to make a bracket off the front of the frame/ neck. I would like to use fork tube brackets, but do not want to write a CAD file and have anything machined.
Post up suggestions, etc.
I have a stock SV headlight, dual Hella setup (can be mounted from the middle or the sides) and a single 8" light with a single bolt mounted at the back towards the bottom.
