I just bought a spare dash for the S model, happens to be sitting right in front of me! Took a look and there's 8 bulbs. All appear to be T5 (just google the equivalent size for your locale)
For the 5 warning lights, as printed on the circuit board and verified on the bulbs, 4 of them are 1.7W. The 5th is 3W and used for the turn signal indicator. I can't see the wattage for the 3 dial lights sorry.
If the entire display is dark you have a connection problem, not a bulb problem.
There are two O/G wires from Fuse 5 to the gauges.
One of them powers the backlight bulbs.
Discussion Starter #5
just my speedo light is out. I have all the wattage numbers from the diagrams, but I can't find LEDs with the little craddle things. Should I just reuse the old ones? Looks like I just gotta unbend the leads on the old bulb, and insert the leads from the LED and rebend, might need to spot solder it. I was really hoping there was already an LED with that little plastic craddle thing that holds the bulb onto the unit.
