Ignore him, yes you want a 'non load sensitive electronic flasher relay' or something that fits that description
2 or 3 wire, it doesn't matter... most people use a 2 wire, but I was unable to find one initially and thus have a three wire one; the extra wire is just an earth that you need to ground to the chassis, so no biggy, tidier without it though
Resistors are gay balls... they get hot which means locating them out of the way (Where they can't melt things), they need to be off the correct size, and they mean more wiring. Pulling two wires from the fuse block and attaching them to the relay doesn't get any easier
(that's the gen2 way, gen1 might be different, but it's still two wires from
somehwere onto the new relay
