1 - 20 of 20 Posts
My 99 SV has a gangster pimp lean. So much that I'm worried its going to tip over one of these days. I can comfortably put a 2x4 and 1x4 under it to prop it up. I'm thinking someone must of leaned the bike over and pivoted on it a few too many times.
I'm wondering if I could just go to a machine shop and have them heat up the kickstand mount and then bend it downwards to straighten it out some?
Anyone had this problem and got it fixed? More ideas? Thanks!!
Administrator
Pics?
Sent from my other shoe using the Motorcycle app
99% chance that it is a completely normal lean... Just buy a swingarm stand for the home and pay attention to how you park on the streets.
If youre that worried about it, buy a new one. Heating and bending the old one could weaken it...
very big dumb
lean wit' it
We've tried on ThatDood's bike to get rid of the massive lean by swapping to a new kickstand, and it was identical with a known "good one". 1st-gen bikes like yours apparently just like to be way over on the stand.
my buddy's hawk is the same way. you can raise it a good 3" and it will still be well over.
metal fatigue from spinning on sidestand, using footpeg as step to get on bike or practicing getting your knee down while parked
I had to replace sidestand mount on mine
part # 6
Really? Are you sure you guys can put a 2x4 and 1x4 stacked ontop of each other and still feel comfortable with the lean your bike has? Please try and LMK.
I'd be surprised if it should lean THAT much.
Part #6 is exactly where I'd have them heat it up and bend.
Really? Dang! A paver would be about the right height. That's crazy.
Well if that part hasn't bent once then I should be OK to heat, bend once, cool, and be happier with the less lean.
Well maybe I should ask if anyone has altered the stand for less of a pimp lean?
Whenever I use my paddock stands on my 02 gen1 I always put a 2x4 under the kick stand first to get it more upright before i grab the spools. It does lean quite a bit and i prefer it to be as upright as possible before propping it up on the stands.
Looks pretty normal.
I don't have any that show the profile too well.
This one (both bikes are 1st gen) is at a bit of an angle to the bikes
So is this one (still 1g)
This one I held the camera at an angle ( the road in the background is level, and yes that tire has been replaced)
I sometimes have to put a sidestand on my 99 race bike when I work track days, since we have to pick up bikes that go down. Using the side stand makes it easier to park the bike. (Otherwise I'd have to find something to lean it on.)
My SV has an Ohlins shock with ride height adjustment that has been set higher, so thew sidestand puts my bike at an extreme lean. Moreso than the OP's bike does.
Not too keen on those adjustable aluminum stands. So, are there any other bike's stands that are longer and straighter than the G1 SV that would fit the SV's bracket?
Not sure about the Gen 1, but a 2x4 and a 1x4 makes my Gen 2 really close to vertical.
I'd make sure the bolts are tight, and if it still bugs you, look for one in a bone yard.
From the pics it looks like your kickstand has had some trauma about 2" down from the bolt.
BannedCampCounselor
I used a GSX-R kickstand.
Milled out the groove to fit the SV bracket and pressed a bushing in to use the SV bolt.
If you want to continue using your kickstand switch, you'll need to weld a small pad to part of the stand so that it hits the sensor when up. I've removed the kickstand switch so it's not an issue for me.
Might be hard to tell from this pic, but you get an idea
1 - 20 of 20 Posts
