so my rear brake was dragging pretty bad
and also was pretty worthless when pressed (untill it locks up)
so i bled the line and took the piston out of the caliper
cleaned it up a bit
now i want to reassemble and see if i did anything productive
or if maybe my master cylinder is out
(sometimes when i would press my rear brake pedal...it would stick in the down position (on) ...but i don't know what that is a symptom for)
my problem is i dont' know how to get the piston back in the caliper?
i never took the seals out to check them....they are still installed
so what hte proper procedure for gettin this piston back in
cleaned it up a bit
