Sounds like you're on the right track. The more slack you have in your chain, the jerkier it will be. Sounds like you have too much.digidelia said:Whenever i'm on the highway or cruising at constant rpm's, the bike jerks back and forth slightly, but the revs never change on the tach.
What could cause this? Loose chain? Any help would be appreciated
Scott
choke whats that hehe.kkesler said:Mine was doing this the other day, and I noticed I had neglected to turn the choke all the way off. Turned the choke off and it quit doing that. I would check to be sure the choke cable is working properly and that the choke isn't sticking.
Kurt
Scott
