1 - 2 of 2 Posts
12.6 is battery voltage. Check your Voltage at 2,000rpm. 13.6 is normal. If the voltage goes up with RPM then check your idle speed. If its at around 1,400 then you have something going on. If its low then that could be the reason for the low voltage. Adj it up and recheck.
Alex
1 - 2 of 2 Posts
