1 - 4 of 4 Posts
I just bought a 04 SV650. First, it's having trouble starting. I used to have this issue on my 03 SV but that was in Detroit in the fall, I live in LA and its 80 degrees outside. If I give it a little gas while hitting the ignition switch it helps. Then when it idles it sometimes shuts off when its not really warm.
I was just out riding and the engine cut off when I was in like 4th gear. I had just accelerated and rolled off the throttle in prep to brake and it cut, so I just restarted mid flight no problem but still...
The bike idles at start just under or at 1000rpm. I filled the gas tank. The engine oil was recently changed (according to the owner). Bike has just under 16k. Valve clearance was good at 10k, again from owner.
1 - 4 of 4 Posts
