I'm on an 08 S model.
I got the FIAM air horn. I also bought the relay.
I'm wondering where to hook this sucker up. What I've read so far is I should use the existing horn wiring if possible.
So... hook up the existing horn wiring to the relay placed back under the seat??? Then run wiring to the front for the horn? It says keep it away from heat and moisture.
What did you all do? Relay? No relay?
Thanks,
Rob.
Thanks,
Rob.
