Nate...one thing I forgot to mention in my blog...which I've now included is that you should look into re-routing your fuel run off tubes. Some people have complained that the run off will get onto the fairing and cause bubbling.
Here is what I wrote:
Also while you have the fairing off, consider re-routing the fuel run off tubes. I read a couple posts where people had the gas coming out, getting on the paint and causing it to bubble. There is a wire loop that holds down the tubes and I simply pulled the hoop out, moved the tubes back so they ran along the frame and then bend the hoop backwards to hold them in place.
