1 - 11 of 11 Posts
What RPM is the idle supposed to be?
I know this is a silly question, but I really have no idea where it should be set to, what do you guys recommend?
I'm fairly sure the suggested idle is between 1,200 and 1,300 RPM. Idle adjustment screw is about half way down on the left side of the bike in case you didn't know, it's white.
it is a silly question, but only because the left side of the bike has a white sticker that states what the idle is supposed to be.
i did the tps mod, and got it as close to 1200 as i could. It's actually somewhere around 1150 rpm, so I adjusted the idle to just under it, so mine idles at 1100.
Thanks guys, I guess mine is missing the sticker, and my knob is black,
But it is now set at a nice and even 1200,
Thanks
Correct idle speed on a Gen 1, according to the manual, is 1200-1400 rpm. I have an 01 and the knob is black.
Hi folks, have a problem with idle speed. I adjusted the slow running speed Gen 1 by screwing in the adjustor knob, the engine had been stalling. Question, that cable goes directly to the front carb. What happens with the rear carb setting? Now I have running on one cylinder at slow speed, then both cylinders, but on high revs, goes back to one carb?? Please help
Front and rear carbs are linked together....so when the idle speed adjust tweaks the front...it's also tweaking the back the same amount. Before messing with the carbs too much....have you checked all the 'tune-up' items? That's the prudent way to proceed so make sure the air filter is clean, plugs fresh and valves are in adjustment. Once all of these things are good to go...and you still have a problem...then it's time to dig into the carbs which CAN cause similar problems when the idle circuits get plugged up. Don't be afraid of the carbs...they're pretty simple things once you get to working on them. Best of luck!
Get a bottle of Fuel cleaner(Local supermarkets sometimes have it) like STP/Seafoam etc and put a good glug in the tank and take the bike for an, "Italian Tune-Up" e.g a really good blast out. Sometimes this is all the system needs :)
1 - 11 of 11 Posts
