Does anybody know the factory idle speed for an 06' sv650? Ambient temp about 67 degrees F, bike at operating temp.
First off, there is nothing wrong with bumping an old thread. In fact, it is probably preferred.sorry to bump an old thread, but my 06 idles at 1000 rpm. Should I bother increasing it? I don't notice any ill effects.
No. That is a different function.Mine idles at around 1k too, but I guess I should raise it a bit. Do you have to calibrate your TPS when you mess with the idle?
Set the TPS a little higher (100 rpm) as your idle and you are good to goMy sticker says 1400...i adjusted it after riding it for a while so I knew it was at regular operating temperature....when i start it up, it goes to 2500 for a few seconds, then drops down to about 1200 till it get up to about 120 degrees...then its at 1400. I've been researching TPS adjustments and everyone keeps saying to set idle at 1200 which is kinda low in my opinion. Been kinda wondering what my tps setting should be with my rpm settings...1650?
It's really easy when you have some decent tools and no reason to get nervousThanks. Been working on getting the nerve to do the tps adjustment...lol. this is my only transportation and I don't often have more than one day off at a time...so I can't make any mistakes..lol
