1 - 3 of 3 Posts
Picked up some used oem rear sets to replace the bent one on the 07 SV650S I just picked up used. The pair I removed had markings with an arrow then -2 L and R. The ones I put on were marked -1 L and R. Can I assume the ones I put on were off a naked or N version?
Beginning in '04, naked and "S" rearsets were the same. In '03, the naked rearsets were lower and more forward, the "S" rearsets were higher and further back. If the rearsets that you put on didn't require a different shift lever and different brake spring, it was probably an '04+ (same as what you took off). Doesn't really matter though, if it works and you are happy with the peg position. Here is a picture of an '03 naked.
Thanks for the pic. The pair I put on seem to be identical to the ones I pulled off and didnt require anything different . I'm going naked with the bike, so I guess it wont matter too much either way.
1 - 3 of 3 Posts
