1 - 20 of 29 Posts
the moter will not turn over..when i hit the start button i hear a loud click noise.I tried to compresion start (in 2nd) but the tire just slide. so i tried to roll the tire while in gear and it will not turn the motor.. like it locked up. Im sad please help..
Not enough information. Have you tried pulling the plugs and then rotating the engine by rolling the bike? (Try a higher gear to make it easier to turn the engine). Does the oil level look OK? Were you doing any extended wheelies? Has the bike sat up for a while?
What were you doing when it stopped running? What were the symptoms before it died on you?
Bump starting an SV is also impossible by first-hand experience.
Are you a 100 pound weakling? I rode around for 2 weeks without a clutch switch, I bumped it everywhere I went 1st 2nd or third. Usually 2nd though.
I do weigh 195 and run a sub 7 mile, maybe that helps.
And you can start the SV on a totally dead battery, but that takes some serious speed, and a lot of effort to fire the electronics
I bet he is going to say something about stunting it. If I remember a while back he threw a stink about it.
Guessing he seized it but we shall see.
1 - 20 of 29 Posts
