I don't have any pics, because, well, I really don't want any photographic evidence of my suckitude.
I'm riding Heli Bars now, and had to add about 3/4" (spacers) or so each end so I could fit all the controls and hand guards.
My plan was to use Swatt 3.5" rise clip-on clamps and a drag bar (cut in half) as a way to get a lot more down angle while still keeping my hands in essentially the same place. Everything was going great until I started trying to get the controls on.
I found out I would need:
* longer clutch cable
* longer throttle cables
* longer brake line
So then I started investigating... Cables weren't a big deal -- Convertibar cables would do the job.
But the way the clip-on clamp was hitting the top triple bolt kept it in a position with too much pull-back. I tried putting the clamps on backwards (which gave me a GREAT position), but that caused a severe restriction of how far I could turn the front end.
I thought I could maybe make it work anyway, but then I saw that I would not just need a longer brake line, but the entire system.
And that's when I realized that what I was really trying to do was a naked bar set-up. A drag bar (set so the bars when straight down with almost no pullback) on regular risers would be about perfect placement.
So I would need:
* risers
* another drag bar (because I already cut the one I have in half)
* either a naked throttle tube and cables, or custom long cables
* naked front brake lines
That all assumes I can drill out the S top triple to get the risers put on (don't know how much of a good idea that is). If not, add naked triples to that list.
But then I noticed that my wiring harness for the right hand controls (starter button, etc) was maxed out, and that I wouldn't be able to get it in the right position.
Kill the project! I'm not about to cut into the wiring harness.
Maybe my next bike...
I'm so ashamed.
* longer brake line
So I would need:
* risers
I'm so ashamed.
