1 - 2 of 2 Posts
Does any on know how to fix a 06” sv650 pump pump? I cleaned it with card cleaner then put it back on the tank I didn’t here it prime I have the connector connected all the way. I’m trying see if it’s wire I messes out and I replace the pump
Did the fuel pump prime before being removed?
If the wires were put back in the wrong position that could cause the pump not to run.
With the fuel pump relay plug still connected, check for 12v on Y/R directly at the back of the plug. That will tell if the pump is getting power or not. If you do see power but still no pump then double-check the wire positions.
You have to be quick because Y/R has 12v power only for the first 3 seconds after the key is turned on.
Rectangle Gesture Font Line Window
1 - 2 of 2 Posts
