1 - 3 of 3 Posts
I ordered my buell xb headlights for my 03sv650s. I have been going thru past threads and my reading comprehension is failing me. I want to wire my lights up using my stock svs light harness. I don't know where to cut wires. Should I cut the wires where they plug into the headlight housing or should I cut wires directly from the harness? Anyone have any pics ? Thank you.
Don't cut your SVS wiring.
Use a male blade connector like this:
Stick these in your stock SVS wiring harness and wire them to your headlight connector.
Or, most will cut the Buell light harness and crimp the male blade connectors and plug them directly into the stock harness.
tk
Discussion Starter #3
thanks for the info I'll try to do the wiring later this week when I have time, If I run into any other complications can I sen you a pm , I see you gave out quite a bit info in other threads about the buell swap.
1 - 3 of 3 Posts
