1 - 2 of 2 Posts
I have currently done the Cam swap on my 02' Race SV, 152.5 mains, 17.5 Pilots, 4 degree advance key, K&N filter and full Muzzy Race exhaust. Does anyone have similar mods that can tell me what their bike Dyno'ed at after the mods. I have Dyno'ed it before at 63HP at the wheel stock.
Thanks.
If you already have a previous dyno reading you should go back to the same dyno on a day with as similar atmospheric conditions as possible and run it again.
There is some variability among dynos, so comparing runs from one to the other is not reliable. Dynos are best used to see improvements. The best criteria is percentage. For example, if you've dynoed 63 and wind up close to 70 you've got a 10% improvement. Also, it's important to look at the shape of the torque curve. A high, flat curve is ideal. The more area under the torque curve the better.
1 - 2 of 2 Posts
