1 - 17 of 17 Posts
Question for those in the know, I have a 2 yr old Yoshimura RS-3 slip-on and since I ride a lot in state parks and wild life areas I have been thinking of toning my exhaust note to a quieter level. Off hand does anyone know if these cans be re-packed and if so would that tone the volume level down a notch?
I love the tone, just want to reduce the volume level.
Thanks
I was hoping to avoid putting the stock exhaust back on parially because of weight partially and because I remember it being overly subdued. However, it was 2 years ago when I last heard that can.
zyclone baffle?
I am not sure what that is, I will have to do some research on that. I think I remember yosh having a zyclone can, is their a baffle I can insert?
FYI, Just went to the Yosh site and this is what they had to say
Q. My Race pipe is too loud, what can I do?
A. The first thing to do is if it has a lot of miles on it, the muffler may need to be repacked! $10.00 worth of Yoshimura Eclipse fiberglass goes a long way in quieting down a raspy muffler. Other than that, Yoshimura tries to keep noise levels to a respectable level without hindering performance. Yoshimura will continue to develop the best performing exhaust systems with a great quality sound and acceptable dB level.
rlsrob said:
zyclone baffle?
The rs3 comes in regular and zyclone flavors. Dont know if its something you can stick in or not. I was just asking.....
Not sure about how to repack the can, I guess I will call my stealer and see if they do it or if I need to send it back to Yosh.
Looks like you would need a rivit gun to put it back together?
If its an aftermarket can, re-packing is relatively straight forward, take out the rivets, install new fibreglass packing and reinstall sleeve. You can also try header wrap, will knock it down a DB or 2, every bit counts. Try getting some sound deadener from a hardware store and put in on the inside of the sprocket cover, it makes a lot of noise. If your aftermarket exhaust has a lot of useage, repacking will give you a few more hp while your at it. It's what the dyno guy said trackside.
I think thats really respectable you want to keep your sound level reasonable.
I realize this thread is fairly old, but it is exactly what I am looking for.
My question is, if you jam even more packing in the can, will it be quieter? Can you put too much packing in?
my brother in law has a cap on his 4-wheeler exhaust to quiet it down a bit. the company that makes them also makes stuff for bikes, though i don't know if anything will fit our exhausts.
check here in the accessories page: http://www.supertrapp.com/product_sections/motorcycle/index.asp or call them and ask if they have anything to fit your pipe.
you put a few discs and a cap on the end of the pipe. it quiets it down and can supposedly also move the powerband around. (http://www.supertrapp.com/technology/index.asp)
Yeah, I had the supertrapp on a car once upon a time. I had repacked it once, but the sound "tuning" definitely comes from their end plates.
My current idea is to cut a section of 2" tubing which will just fit into the can's exit pipe. Tubing will have a slash cut at the end that pokes into the can, such that if positioned correctly, it would exactly mate with angled interior baffle and effectively choke the flow 100%. By rotating this insert and making the slash cut NOT match up with the interior baffle I should be able to regulate exactly how much exhaust passes through, from 0-100%. I know I don't want to shut it down completely , but it will be interesting to play around with it.
Discussion Starter · #15 ·
Cool, to see my old tread reappear.  However, the bad news is that I must be a major slacker and an inconsiderate arsehole because I am still riding around with that noisy exhaust.  What is even sadder is that every time I ride I think to myself that I should fix it.  I think I might start with the repacking route first and see if that mellows the noise level a bit.
there's always the cheap way; stuff a sock down there. use the other one to cover a spare helmet shield.
of course, that leaves your pants unstuffed....can't help you there
Well, there is another thread about Riverside county, near L.A. that is generating discussion about exhaust noise, so maybe this thread will continue on.
For those interested, I cut up a tin can to create my own baffle/restrictor and fit it into the end of exhaust pipe. It DID reduce sound a bit, yet kept the throaty thump that stock exhaust totally kills. Restrictor was c-shaped, so it's springiness held it in place in exit tip of can--for a while. Somewhere on my ride it blew out, so now I am a litterer as well as noise polluter. Seriously though, I do plan to come up with something like this that is "tunable", simple and cheap. Keep the throaty, lose some db.
For a simple, 5 minute experiment, it worked well, while it lasted.
1 - 17 of 17 Posts
