1 - 10 of 10 Posts
I have about 16K miles on my bike.
Sprockets aren't worn. Chain looks fine. I maintain (clean, lube and adjust) regularly. How do I tell if my chain needs to be replaced?
Thanks!
If the sprockets are getting pointy or if the chain rattles when you shake it, they're beat.
Otherwise I'd just keep them clean and lubed.
there can be tight spots in the links also. when you put the rear on a stand the wheel will spin easy then be hard to turn.
also when you are at the adjustment area, time for a new one
The owner's manual has a procedure for measuring the chain to see if it's worn out. Measure a couple of different sections.
Thanks!
as already posted, refer to manual, look for tight/loose syndrome.
if your chain is worn, replace your sprockets too, even if they look good, they are worn with the chain, and will make a new chain wear prematurely, your chain cost more than the sprockets, and it will be a difference of your next chain lasting 8,000 miles or 16,000 miles
Someone else gave me a neat piece of advice. pull the chain away from the rear sprocket at the 3 o'clock position. if you can move it away from the sprocket, then they are both(chain and sprockets) shot, and need replacement.
Glad I was this thread as I was just going to ask a similar question. My chain with 12,500mi seems to have one tight link. I can tell when I have the bike on a rear stand that it labors at one point. I would assume my chain needs replaced?
What are good replacement chain/sprocket combos for commuter type of use? Where are good places to get the combos? What should I expect to pay?
bang for the buck, cost per mile basis, you can't beat OEM sprockets, others are cheaper but don't last near as long
Do you have chain recommendations? What specs do I need in a chain?
Did I read before that you have some sort of oiler for your chain so you don't have to lube it or clean it all the time?
1 - 10 of 10 Posts
