21 - 24 of 24 Posts
Take the switch off and take it to a good locksmith shop. I've done this and in 10-15 minutes I had 2 keys for $15.  8)
ths might not help you but somebody tried to steal my SV and cut the ignition wires to start it; So I had to buy a new ignition set up and it came with 2 new keys I only went $280 in the hole. You can install it by yourself
what about the gas tank and storage lock?
Your gas tank and storage lock do not use all the tumblers that the ignition does.
That being said, you need to use the ignition as the master key. Once that key is replaced it will work for the tank and seat.
I’m not sure if a key is made for the tank if it will work for the seat, again not sure if they use the same tumblers, not sure if that answers your question.
Sent from my iPhone using Tapatalk
21 - 24 of 24 Posts
