Hey guys I did some searching around the forum and didn't really find a write up for this simple task so I figured I would provide a few pics of the process.
First you need to buy a LED flasher relay. They can be found online or at your local parts store.
Locate the fuse/relay under the passenger seat. Pull out the relay so you can access the required wires.
Using a SMALL jewelers flat head screwdriver you slide it into the top of the plug (as if it were the male prong connecting to the female plug) to release the wires from the harness plug.
You can purchase the male connectors at the hardware store so you will have a plug-and-play LED relay.
Connect the Male (relay wires) to the female (OEM harness wires) together and cover with shrink wrap/electrical tape. The solid brown wire (OEM) is the positive for the relay and the light blue (OEM harness wire) is the negative connection to the relay.
Button up the rear end and you're all done. Install any LED's you want and they will flash at normal rates.
