1 - 3 of 3 Posts
Hey guys !
1st time posting here, hopefully it's in the right forum.
I bought my first ride, an a friend has given me aftermarket blinkers, that blink by themselves (you know, the kind that blinks from once side to another ?)
If I simply switch them with the stock ones, they start blinking all crazy.
How do I bypass (?) the relay (?) to set them up properly ?
Thanks !!
If it's blinking fast then its hyper blinking. Your new signals are probably LED as opposed to a standard bulb style.
LED light relay
So I used a relay to control the timing of my blinkers. To the best of my knowledge you could let it blink as is with no harm but I cant tell you that with 100% confidence. The relay posted above work for my K19 SV but you'll have to make sure the pins are the same as on your bike.
Hope this helps
Discussion Starter #3
What I meant by "it's blinking fast" : they are LED blinkers that blink on their own, the "blinking" is included in the blinker ? Does that make sense ?
It just needs constant current to be blinking.
So if I put it on blinker relay it just kind of "double blink"
1 - 3 of 3 Posts
