I've hard I can lose some weight by chopping off the end of the subframe from my track-only bike. How much can I chop off? How much should I chop off?
It's an '03 subframe on an '05 frame.
Check the rules for CCS - I am pretty sure there is something about subframes for Superstock
you can lose a lot of weight by using an 04+ subframe. the 03 subframe is steel. starting in 04 they're aluminum. is there a reason for using an 03 subframe? the subframes are also slightly different. i'm pretty sure you'd have to use a newer seat. wera doesn't allow subframe mods for superstock. i'm pretty sure ccs doesn't have any subframe restrictions, but i'm not 100% sure.
