1 - 11 of 11 Posts
I put on my 47t sprocket and realized the chain is too short. Im going to add a few links. How many do you think i should add
Sent from my DROID RAZR using Motorcycle.com Free App
As many as you need to make it fit.
Seems very situational to me. Not like we'd be able to come up with an exact answer. Especially with such little information.
Are u putting your old chain on a new sprocket?
Wheel should be in the forward third of the adjustment range, that's the correct number of links.
Im going to add a few links. How many do you think i should add...
Two links (min possible without resorting to a 1/2 link kit). But, extending chains and running multiple master links reduces reliability and is generally considered a kludge.
Also be sure to put the master link clip on in the right direction. If the chain were to contact anything on its loop aroudn the swinger, you dont want the clip to pop off.
BannedCampCounselor
Even better, use a rivet master link and not ever worry about the clip.
I guess I should explain a little better this is only temporary with a used sprocket on a used chain. Only to see if I'm going to like the 47t sprocket. Then i will order my 520 kit.
Guess it would be too easy to figure out difference in number of teeth between old an new sprocket an that should be equal to the number you need to add provided its an even number, I'd say +1 on using rivet masterlink even tho I'm not sure how safe it is to use two master links like one or two links away from each other I'd say that a lil unorthodox and if it a temp thing I'd say use it temp as in like two ten min rides.
Im using press on links. 2 extra links sound good?
Yes, two extra links will do it. To be 100% sure, get your parts together, then wrap the chain around the sprockets and do a direct measurement.
Even with the extra links there is gona be some resistance getting chain around the back sprocket. It not gona be like throwing a sheet over a bed. You may need to use old school bicycle chain method where you get it started (on bottom) an spin the wheel forward.
1 - 11 of 11 Posts
