1 - 17 of 17 Posts
want to change the grips. how hard are they to come off? It may lead to changing the crome handlebar to a matteblack one. since i have zero experience removing stock grips or any grips for that matter, maybe here i can get some insight on how exactly both come off.
yup, well i personally use scissors. what are you going to do with the old ones anyways? throw them in the trash after the sit in a box for years? it only costs $15 for another set, so meh.
Cut them off with a razor blade, your going to put a new grip over where you are cutting.So if you scratch your bar it's nothing to stress about. Just don't press down real hard and finesse it. Clean the bar with alcohol and put the new ones on with an air compressor. It's really not a complicated task.
:roflmao:
WOAH! I love it! Sorry to thread jack, but that is great.
I have posted that several times in the last couple of months and not one comment, geesh ;D.
If you want to save the grips, like mentioned you can use air or you can slide a thin screwdriver under the grip and squirt some WD-40 in there and they will slide right off. Just make sure you clean the bar well before installing the new ones. If am just doing work to the bars I use the WD-40 method. If I am changing grips I just cut the old ones off.
1 - 17 of 17 Posts
