After riding my dad's Wide Glyde, and I've always wanted to add a relay in case I ever added accesories, I realized I wanted to have a commuter grade horn on my bike.
Separate relays for horn, and accessories, correct? In order to maintain the usuage of the stock horn button.
But thinking about it, I also want to retain the stock horn, in order to use in those situations where the power of a commuter grade horn wouldn't be needed.
So I'm thinking of getting a toggle switch, and wiring it into the horns relay.
But I'm not sure what kind of toggle switch I want. I'm positive I can't use a regular toggle switch, and I need a double pole. I'm thinking an ON/OFF would work. ON would be the commuter grade, and OFF would be the stock horn. Does that sound like it would work, or should I go with a ON/OFF/ON? Going with an ON/OFF/ON could possibly put me in the position of having the horn off when I need it, so I think a ON/OFF switch would be best.
I'd mount the switch on the inside of the fairings, that little panel behind the lights or something.
I also almost want to add one of those safety switch covers (ex: Fighter Jets).
Am I on the right path?
